My Overkill solar BMS phone app has a On/Off switch for charge and another for discharge.
2.4.6 External Switch
An optional external switch can be wired to the BMS via the included 2-pin pigtail (JST-XH, red/black wires).
If the configuration option is enabled within the BMS, discharging will be disabled when the switch contact is
open. When the switch is closed (or a jumper is in the place of the 2-pin connector), the BMS will operate
normally.
● External switch: Set this to True if you have an external switch wired to the 2-pin connector, as
detailed in section 2.2.6.
