12VoltInstalls
life passes by too quickly to not live in freedom
Welllll… some of us penny pinchers have different motives than W/$ but it comes off that way.usually suggest Epever because users on this site tend to be penny-pinchers that cann't see past W/$. The suggestions for the high-end, tier-1 products that I myself buy are generally not well-received.
I personally appreciate your explanations though I may disagree with your conclusions. Doesn’t mean you’re wrong or I’m right empirically- not at all. In fact I’d say in a stratospheric view your advice is appropriate.
Nevertheless, my tendency for leaning ‘cheaper’ is predicated most often by my read of the OP intentions and goals with whatever context they presented.
Often their stated goals are not achievable within their economic mobility; or they don’t know what to think about to make their systems function as they wish. Discussion of lower-shelf products nearly always devolves to their limitations or negatives which is great because then they can make an informed, educated decision.
Also often: people in general are unaware they are not discerning - or otherwise are somehow unable to discern- the difference between wants, needs, and wishes. So their product research gets falsely focused on products they think they can afford rather than figuring out a plan and goal to complete- because their goal is actually a wish/want. So they wind up with cloudy judgement because they operate in the realm of ‘want’ rather than “intent.” So recommending good track record mid- and lower-shelf products helps them arrive at workable solutions without having to develop critical thinking skills without much notice.
Which probably is in a metaphorical fashion a parallel behavior to confirmation bias for those who resist tier1 products.The suggestions for the high-end, tier-1 products that I myself buy are generally not well-received.
At the same time I probably have some “behavior guilt” myself ??
Though I’d have to ask, “do you blame me?”
Other than all my wiring&cabling which is top shelf - and realistically my solar panels are quality- I’ve had zero functional failures with the mid/lower shelf products I operate with (well other than the known bug of high-voltage spike and cutout with Epever SCCs which probably doesn’t or won’t show up with LiFePo systems due to LiFePo’s charging profile).
I just want people to make informed decisions and not just go cheap or go high and sell a kidney merely based on dollars. The dollars are what they are once you have something that will meet an actual intent. I’d interpret your advice as seeking that end as well.
