Using the Epever Tracer AN 100A charge controller. It only has 'solar in' and 'battery out' cables!! How on earth is it supposed to know what the load current is to charge the batteries correctly?
In other words, what additional magic box do I need to tell the Tracer AN what current the loads are taking, it always shows zero in the display?
I'm using two daisy-chained Victron Quattros to give 10kVA inverter output but the VE-Bus on those has no third-party output possibility as Victron say that is "mission critical" to synchronise the inverters so I need some other way to tell the Epever AN what the load is. I'm trying to avoid forking-out for a Victron Color GX for what would seem to be such a simple requirement, can anyone help with a simpler solution?
Many thanks...
Many thanks...
