Donnie - did you get your system running?
I've been monitoring my PB2A16S20P religiously. I finally feel my BMS settings are in a sweet spot for new MB31 cells. As I shared in this thread above, I too was confuzzled about many of the BMS settings. One of the key experiences I had was to recognize the settings that were closely related or relied on each other to function properly(?). Yeah, I'm not an expert but did have a background in electronics and technology decades ago. Multiple PLC logic/equipment software settings - often work in unison.
I started with settings from Steve S. here on the forum, and Andy at Off-Grid Garage. Paying attention to "what a setting does" was as important as the setting. If these screenshots of my first full charge help, using combined solar and generator power, then I'm glad I came across another enthusiast working on their first BMS.
If there are any glaring discrepancies, or other people's opinion, because there's at least one in every crowd, that'll be cool too.
Here's my equipment:
Renogy 48V Solar Inverter Charger - NOT connected/communicating with BMS
JK BMS V15 PB2A16S20P Standalone
EVE MB31 314aH battery pack
Heleine 585 panels x4 2S2P configuration
Predator 3500 generator (under heavy 20A load 6hrs = 2.5 gallons) used once in 10 days
Here's my BMS settings after my first full charge to the battery after putting into service. I have a lingering alarm but it's not showing up on the display or my log. I'm not ready to do an update and believe in the if it's not broke there's not always a reason to fix it methodology.
Best regards,
Bill
