What should my next system be?
cdallas
Earth
I currently have a small 12v system that is running 2 freezers. I have a 100/30 mppt, a single 200Ah lifepo4 battery and 500 watts solar, but my string of panels is not optimized for sure. Just what I have at the time. 3- 100 watt panels. I threw a 200 watt folder style panel in the mix and they are all wired in series. The folder is wired in parallel so I am not getting the best I can get for sure, but again, what I had at the time.
The system is good when it's clear, but I do lack capacity for sure for rainy/cloudy days. I have a charger/power supply as back up to turn on at 12.8v so I don't lose the freezers.
1) Should I add another 12v 200ah battery in parallel and get a slightly better mppt so I can add a few more smaller panels, so I do not need to buy a 24 volt inverter on top of the battery?
2) Should I make the jump straight to a 48 volt system and just bite the bullet on the cost? (this seems more logical as it will allow for expansion much easier)
I have room for potentially 9-10 large 80+ inch tall x 40-45 inch wide panels, but would start with at least 5 near 400 watts and around 40 volts so I can meet the 120v needed for the all-in one.
My next conundrum would be the all-in-one... I am leaning toward the EG4 3000 EHV-48 as I would doubt I would have enough room for the 6000xp 8k watts of PV.
Also, If I do end up having enough space for 2 rows of 5 panels, giving me close to 5k PV for th 3000 ehv, should I buy enough panels up front so they are all the same? I can't afford to buy new, so I would buy local off facebook most likely. Chance of getting the exact same (if i were to expand the array down the line, seems slime to none)
This system is a stand alone, NOT grid tie. It will power fridge/ freezers and charge power banks, tool batteries, ect...
Thank you for any input and ideas
Your post seemed to not get any traction. I did not see it til now or I might have commented.
If you can get a good deal on panels, and your loads are within a 3kW at 120vAC AIO, there are a few out there besides the EG 4 offering. I have had good success with rebadged SRNE units and reasonable success with Sumry (24vDC). Unfortunately prices have been rising but there are still deals you can find.
There are reviews here in sub forums about particular AIO's if something grabs your fancy.
