MarkSolar
I have a storage building for tractors and equipment, no power in the building. I need a solar system to power the 120v battery charger that's integrated into a battery operated boom lift. The lift has 4 of these Trojan batteries. I never let them go below about 1/2 charge. I'm trying to figure out what size battery I need on a solar system to run the lift's battery charger long enough to recharge the batteries.
If I work from each of the 4 lift batteries being 1.5kWh, that's a total of 6kWh, and if they're half charged that means I have to put 3kWh back into them. Is that the right way to think about this? I've put a meter on the system when it's charging, it briefly draws 9A@120v, then quickly drops to about 7, then 6 and finally 4A after an hour or so. It takes 6-8 hours to fully charge from ~1/2 discharged state.
I can always choose when I want to do the recharging, so I can wait until the morning of a sunny day and plug it in. So the panels can help the battery with the charging. So if I get a battery that can deliver 3kWh in 8 hours, that's 375W which is 30A. So what kind of battery do I need to deliver 30A for 8 hours and only be about 1/2 discharged so I don't damage the battery? I guess in theory if I have a 375W panel I don't need any battery, so I'm not sure how to think about this.
