JUMPSTART
#4 AWG Solar Panel Wires (coming in house) ...(Current Shunt / Volts / Amp Meter) is installed.... Transitioned to ((( #10 AWG ))) ... Anderson 30A Connectors into my "All In One" Solar Generator .... It can only pull 15A Max.
(Current Meter Read 30+ Amps Today)
....Not sure how this could even happen as the generator can only pull 15A.
Installed a nice 15A inline slow blow solar fuse. My reason was basically to protect the solar generator (that most likely has its own anyway)
Alarm went off on the meter and I noted 30 amp reading and the 15A fuse was hot, but did not blow (not even after some time)
#10 AWG would be my smallest conductor.
Figuring to change this fuse to a 30A = 10AWG (THHN/THWN... Good for much more)
I guess I don't need a nuisance trip and this is a rather nice permanently crimped inline fuse (Signature Solar) that can't be easily changed so....
.... I guess the best thing to do is protect my #10. --- The 15A didn't blow forever so this one can't.
I hooked up the current shunt on (-) side .... 5 ft from the generator (Could I Be Just Getting False Readings)?
