Oh were it just the generator I'd have no issue at all. The 3000W covers most anything I really do beyond starting very large inductive loads. But when it's going to spend 4 to 6 hours with 1600W siphoned off then its a different story. I imagine once solar is in place that might not be as much of a concern so I grant that.
Alrighty. I thought you said 5K watts, not 3, but maybe I wasn't paying attention. On my off toad trailer, I have 200watts solar, + 600 portable in needed, 206Ah LifePo4 + 2000 watt inverter if needed. Obviously, I don't run the 13K AC off the batts, and rarely the micro. Water heater and furnace are propane, as is the fridge.
The small genny is just to power the AC when needed, and to charge the batts when no solar, so maybe not all that dissimilar to the tiny house thing, I venture. - or maybe not.
Probably all manor of reasons people get whatever it is that's called a "tiny house" now. For myself we built the largest structure we could afford to dry in as a getaway cabin. It's not a garden shed and its not really a house. It kinda sits in the middle. For us efficiency is a distant 3rd or 4th. Main consideration was to have a system we could grow into and expand and that could handle most tasks without power management being top-of-mind. I also prefer these Chinese electronics to spend most of their lives working in the low end of their specs. Will be building this system like the cabin itself. A little bit at a time.
Yeah, I get it. I am no EE, just trying to compare your interesting project with a somewhat similar use case. It seems to me that with a "Tiny" house you have a huge advantage over any travel trailer or camper in that you can insulate to whatever specs you want. Travel trailers are mostly all very poorly insulated. I am just speculating but from what I know, good insulation isn't cost prohibitive, and can make a large difference in energy consumption. Sounds like low hanging fruit to me, anyways.
As above, for me its having lots of headroom if someone is showering with the pump running, the microwave is on, and my daughter is using the kettle for tea. Were it only ever going to be me there I'd live without a lot of that, but since it's wife and daughter, making sure for the most part power is not something to juggle I went oversized on the inverter.
Do you mean an RV style water pump, or this a pump part of the combi unit? My RV pump doesn't use much power. Hard to avoid the power drain from the micro, but I don't use mine much, so not a problem for me off grid. But it's understandable that you want to include that.
I do all of my cooking with propane, it sounds like you need/want electric. That's cool.
Not really trying to refute you here either, just explaining where I'm coming from on my system.
It really didn't sound like you were refuting my comments, I was just expressing my interest in your project. It sounds like fun to me.
