I have a 325w Polycrystalline solar panel
I want to use it to pump my pool water to a DIY pool heater the material on the pool heater is 100ft black poly utility pipe coiled on a 4x4 plywoood all painted black.
I can get 89deg F water temp when attached to a 120v submirsible pump on a sunny day.
I would like to switch this pump to one the solar panel can run continously when possible.
I would like to know what type and size solar pump (not too costly) I can use and other components that might be required for the system.
Thank you in advanec
