Are you talking about seeing it from across the room with big numbers on a big display?Would like to be able to monitor my system from a far
Across the room is not" A Far"Are you talking about seeing it from across the room with big numbers on a big display?
Or something connected to the inter webs?
Venus OS/Victron has built-in MQTT publisher and see this thread for JDB BMS to also get MQTT topics from there.I use victron equipment with bluetooth. It also has an internet option.
i would be interested in seeing a monitoring device that would be able to constantly send something over the web and do recording. I’m sure it’s out there, but have not found something like that.
I think to do what I’m asking to interface with not just Victron but a JDB BMS and Samlex Inverter, I’d need to hack the source code and write some sort of program myself.
what is your inverter brand
I have a Snat inverter and A SNRE charge controllerwhat is your inverter brand
150 bucks, 2 weeks delivery, three or four settings, done.solar assistant seems to work for a number of people, but it is too difficult for me
unfortunatly most, if not all of above do not work with never voltronics/mpp solar inverters..List of software I use
GitHub - manio/skymax-demo: https://skyboo.net/2017/03/monitoring-voltronic-power-axpert-mex-inverter-under-linux/
https://skyboo.net/2017/03/monitoring-voltronic-power-axpert-mex-inverter-under-linux/ - manio/skymax-demogithub.com
GitHub - ned-kelly/docker-voltronic-homeassistant: Programmatically read data from your Voltronic, Axpert, Mppsolar PIP, Voltacon, Effekta etc Inverter and send it to Home Assistant via MQTT - Works with RS232 & USB!
Programmatically read data from your Voltronic, Axpert, Mppsolar PIP, Voltacon, Effekta etc Inverter and send it to Home Assistant via MQTT - Works with RS232 & USB! - GitHub - ned-kelly/docke...github.com
GitHub - coxifred/pimpMySuperWatt: Python software for SuperWatt VM II 3KW/5KW & Axpert Max 7.2
Python software for SuperWatt VM II 3KW/5KW & Axpert Max 7.2 - coxifred/pimpMySuperWattgithub.com
GitHub - lluiscab/MPQTT: MPQTT is a linux program used to extract data from Voltronic / Axpert / MasterPower inverters and sending it to MQTT for use in Home Assistant
MPQTT is a linux program used to extract data from Voltronic / Axpert / MasterPower inverters and sending it to MQTT for use in Home Assistant - lluiscab/MPQTTgithub.com
GitHub - njfaria/SolPipLog: Logger for the PIP Inverter series ( USB / RS232 version )
Logger for the PIP Inverter series ( USB / RS232 version ) - njfaria/SolPipLoggithub.com
https://github.com/jblance/mpp-solar![]()
GitHub - dj-nitehawk/Hybrid-Inverter-Monitor: Monitoring application for hybrid inverters using the Voltronic communication protocol & JK BMS via USB port.
Monitoring application for hybrid inverters using the Voltronic communication protocol & JK BMS via USB port. - dj-nitehawk/Hybrid-Inverter-Monitorgithub.com
can send to home assistant domoticz and other
https://github.com/TaiyoMatsumoto/VoltronicAxpertSolarMonitorBMS
Grafana dashbord
What protocol and interface you try?unfortunatly most, if not all of above do not work with never voltronics/mpp solar inverters..
tried my 8000 max's, you may find a bunch of questions in the issues section of ned kelly's githubWhat protocol and interface you try?
If WatchPower software works, any of this will work, with smaller incapability.
Are you use protocol IP30MAXtried my 8000 max's, you may find a bunch of questions in the issues section of ned kelly's github
tried both, gave me only partial results ( unfortunatly)Are you use protocol IP30MAX
https://github.com/jblance/mpp-solar and https://github.com/ned-kelly/docker-voltronic-homeassistant
use same base
