houseofancients
Solar Wizard
unfortunatly most, if not all of above do not work with never voltronics/mpp solar inverters..List of software I use
GitHub - manio/skymax-demo: https://skyboo.net/2017/03/monitoring-voltronic-power-axpert-mex-inverter-under-linux/
https://skyboo.net/2017/03/monitoring-voltronic-power-axpert-mex-inverter-under-linux/ - manio/skymax-demogithub.comGitHub - ned-kelly/docker-voltronic-homeassistant: Programmatically read data from your Voltronic, Axpert, Mppsolar PIP, Voltacon, Effekta etc Inverter and send it to Home Assistant via MQTT - Works with RS232 & USB!
Programmatically read data from your Voltronic, Axpert, Mppsolar PIP, Voltacon, Effekta etc Inverter and send it to Home Assistant via MQTT - Works with RS232 & USB! - GitHub - ned-kelly/docke...github.comGitHub - coxifred/pimpMySuperWatt: Python software for SuperWatt VM II 3KW/5KW
Python software for SuperWatt VM II 3KW/5KW. Contribute to coxifred/pimpMySuperWatt development by creating an account on GitHub.github.comGitHub - lluiscab/MPQTT: MPQTT is a linux program used to extract data from Voltronic / Axpert / MasterPower inverters and sending it to MQTT for use in Home Assistant
MPQTT is a linux program used to extract data from Voltronic / Axpert / MasterPower inverters and sending it to MQTT for use in Home Assistant - lluiscab/MPQTTgithub.comGitHub - njfaria/SolPipLog: Logger for the PIP Inverter series ( USB / RS232 version )
Logger for the PIP Inverter series ( USB / RS232 version ) - njfaria/SolPipLoggithub.comhttps://github.com/jblance/mpp-solarGitHub - dj-nitehawk/Hybrid-Inverter-Monitor: Monitoring application for hybrid inverters using the Voltronic communication protocol & JK BMS via USB port.
Monitoring application for hybrid inverters using the Voltronic communication protocol & JK BMS via USB port. - dj-nitehawk/Hybrid-Inverter-Monitorgithub.com
can send to home assistant domoticz and other
https://github.com/TaiyoMatsumoto/VoltronicAxpertSolarMonitorBMS
Grafana dashbord
