He has done that for years - might not be on his list?You might also want to test for HIGH temp cutoffs.
I actually did find something important missing in your videos. The exact model of the BMS the simple 12Vs have. It would help for considering to rebuild them into a 16S or generally figuring out how to charge them for top balancing because some BMS models might have static setups.Currently my videos follow this protocol:
When it comes to build quality assessment, I have to go with what I see. I can't list out the millions of issues that arise in these builds.
- Do a capacity test
- Check for overcurrent protection
- Once I find the maximum continuous load without tripping over current protection if it's present, I do a high c rate capacity test
- Hit it with a heat camera while I'm doing above testing
- Check for low temperature protection probe and test it
- Search for loose connections
- Point out globs of solder if present. Ensure proper temperature was met for solder to flow and create good connection
- Price comparison
- Check bus bars and balance lead for connection issues
- Insulation between the cells
- Proper fixation for cells. Compression not necessarily required but they need to be fixated
- Check if balance leads and main supply conductors are protected
- If the BMS is excessively small, do a load test pushing it to the limit. Use heat camera.
- Check for cell count. If it's not a 4S or 16S pack, will mention it. 15S is not compatible with 16S systems.
- Mention if it's UL listed
- Check for DC rated circuit breaker or fuse. MCCB ideal.
- If battery is being connected to inverter where closed loop communication is easy to set up, I will test it out. I usually avoid doing this because I hate communication.
But when it comes to actual testing, do you guys think I should do more? What do you think I should test on every pack? Is there any crucial things that you think I'm missing?
You may already do this but since I am Data constrained I do not much watch videos. Weight and size measurements of battery and see if they correspond to what the Seller claims they are.
That's a great point. I remember about 5 years ago they mentioned that they had some UL that they conformed to where they had to drop test. Pretty crazy this didn't catch it.Do the FedEx drop survival test.
That's not physically possible for what I meant. Most 12Vs are purely isolated with their BMS self-contained (no communication port or bluetooth).Overkill app lists the BMS model
A large percentage of new solar people just start at 12v. I know I started at 12v many years ago because it just felt safer. I've changed many car batteries and working with 12v was safe in my mind. At the time, thinking about 48v just scared me that I might electrocute myself. A few years later, I went to 24v by putting 2 batteries in series. Replaced all the 12v gear with 24v equipment. Blah blah blah. Yea, i regret spending all that money and should have gone to 48v from the beginning. But in doing so, I built confidence in working with batteries, inverters, solar panels, etc. Learned some safe practices and what not to do. Even back then I dead shorted a 12v battery and burned my hand pretty bad. If that battery was 48v, I don't know...Less testing and teardown of 12V batteries please.
Can't be very important in todays 48/51.2V markets.
Luring yahoos to buy 4 and "make" a 48V battery with all its accompanying problems.
Better to focus on server rack or standing versions of 48/51.2V.
Inverters/SCCs/combiner boxes etc. is nice.
I-BMS system etc. for control/overvies of larger installations.
Remote control of PI5/tablets with BT for control room over CAT6 etc.
But he started with campers and RVs and motorhomes and that is a huge amount of his followers. The RV community seems to prefer big Ah single batteries or parallel small batteries for 12v still. I’ve been to many installers. They still peddle battle born 12v even in 2025!Less testing and teardown of 12V batteries please.
And here is a fresh post with broken main terminal of 12V, 100Ah battery.Holy cow can you link a post to this? Use my impact on these every single day and never had it break
Test the heaters! (if any or if BMS supports it)
