What tightening torque for my mb31 cells 🤔
marty35
France
Hello, I searched everywhere on the forum but I did not find at what tightening torque I should screw the threaded rods on my installation. 4 M10 threaded rods in zinc-plated mild steel, 8 cells of mb31. I am French so if you could give me the value in Newton meters I would be grateful 😃
I asked chatGPT and he answered me 3.5Nm but it is really very little 🤔
Thank you for reading me, looking forward to chatting with you.
Unfortunately, they will not be used given the little compression to be exerted on the cells, I thought it was much more and that the whole thing would hold up on its own.
Oh , I thought it would to.
I'm sorry, I don't know the call calculation for any of it. Just thought I would say hi
the technical sheet does not give the tightening torque of the rods and in any case the example shown there is made of 6 threaded rods.
Torque of rods will depend on thread of rods, elasticity of material (thickness of rod) and number of rods to achieve the 300Kgf pressure specified - quite a few threads about this on here. It's not a lot of pressure needed.
You are going to have to calculate it from first principles, ie the contact area, force pre mm2, compression from the specs, number of rod, physical property specs for the rods such as tensile strength etc.
bolt torque is calculated by the distance torque is measured (1 meter) divided by the radius of the bolt
(the lever arm of the force in your case 5 mm) , so 1000/5 = 200 times multiplication of the force.
then multiply by number of bolts.
