These are going to be wedged between eva foam in a milk crate. The milk crate itself is going to be mounted with a foam board under it also to absorb bounces. Just need some type of tape to hold the cell together and keep them from shifting. Once in the crate the cells will also be strapped to the crate with heavy duty velcro straps.Tape is the last thing i would consider in a van build.
Research thick insulators between cells, plan on bolts through heavy end plates, to keep tension on the cells even, plan to use springs, and plan for the structure to be mounted securely for vibration.
These cells are NOT durable.
Serious consideration should be followed in a mobile environment.
KaptonMaybe I need to rephrase my question. What type of tape should be used to secure lifepo4 eve 280ah cells together?
Let me be clear.Maybe I need to rephrase my question. What type of tape should be used to secure lifepo4 eve 280ah cells together?
Curious what you recommend using as rigid plates? Especially thin ones.You need to use rigid plates at the ends just slightly larger than the cell size, threaded rods at the corners and middle on the sides to maintain compression.
IF you had explained what you were doing, it would have been a simple answer.I never mentioned how I am insulating the cells or how I am compressing them. Now did I? The tape is to make it easier to place and remove the battery pack into the compression mechanism and milk crate. Dang, I really thought it was a simple question and assumed I did not need to post detailed plans of my battery build.
You have to realize we've seen people use nothing but tape to hold things together which have repeatedly resulted in disaster. So yeah. If you don't provide those other details, we are going to assume you're doing the same thing and feel very strongly about that.I never mentioned how I am insulating the cells or how I am compressing them. Now did I? The tape is to make it easier to place and remove the battery pack into the compression mechanism and milk crate. Dang, I really thought it was a simple question and assumed I did not need to post detailed plans of my battery build.
