Thanks for all that info. I had originally decided to get a 1200 BTU unit and found a few that were 120 V. I don’t really understand how splits phase units operate with both 24 V and 48 V. I don’t know that much about these types of electronics. How does a split phase all in one deliver both 48 V and 24 V, and what are the benefits of running a 48 V system over a 24 V system? Thanks again for your help!250 AMPS vs 125 AMPS = No biggie. Especially for Mobile applications.... I have an ambulance and am doing that very thing. (2) Growatt 3000 in split phase for 120 and 240 needs. EG4 series 3 24v 5.1KW 200AH x 6 = 30KW limited to 3000 watts 120v per side or 6000 240. Soooo completely doable. All U.S. Military vehicles are 24V or a 12v/24V combo pushing over 400AMPS out of their generators and are SLA.
If you want to run large panels you can (Ambos support their weight and structural integrity better than all other vehicles because they actually perform rollover tests with them) If your out west in the summer 9000BTU will Barely get you by. I'm going 12,000BTU because you can get good SEER ratings at 120V anything above 22 seer and your looking at 240V. Watch the Youtube vids on Mini-splits and pay attention to the draw. It's usually 150 - 500 watts nominal. When you insulate your box retains temp, thermal bridging and heat induction are going to be an absolute pain. Also 12000 BTU does a better job of dehumidifying which will keep mold out. Since you will be running 24V you can use military inter connects like "Slave Cables" and HWMMV shunts which are cheap on the web.
