I can either do 4 panels at 100 Volts / 20 Amps with a expected 87 volts, or I can do 3 panels at 150 Volts/10 amps with 143 volts coming out the end... Also this is "open circuit" voltage. Should I be basing this off VMP instead? If so then the voltage drop might be more with the lower VDC that would be coming thru.
My original plan was to hook it up and measure it in real time... But I'd rather have a clue which will work better up front.
My charge controller says its good up to 170 volts, so I don't see why either would not work.
But which will give me more real world watts?
I ended up with this charge controller https://www.amazon.com/dp/B0827DWCL6?psc=1&ref=ppx_yo2_dt_b_product_details
I hope one day to "upgrade" it but given its price point/availability/specs this is what I have for now. But I've yet to find its mppt voltage range.
Thanks for any input/help!
