crossy
Solar Wizard
Pretend it's a British motorcycle (Norton, Triumph, BSA) and just give it a drip-tray
Like an old Jeep. They don't leak, they mark their territory.Pretend it's a British motorcycle (Norton, Triumph, BSA) and just give it a drip-tray![]()
Wow. Wouldn't want to say that three times...are Hydnum repandum hedgehog mushroom, lengua de bou or lengua de vaca.
Looks great.Finished my backyard fuel storage project today.....
What are those brown cardboard box looking things next to the propane tanks?Nothing flammable near the fuel!
I bet they are new prefilled tanks. my small tanks of freon come in little tanks roughly the same size as propane and they are always in cardboard boxes from maker.Looks great.
What are those brown cardboard box looking things next to the propane tanks?![]()
Looks great.
Thank you!Looks great.
K-1 Kerosene - the cardboard boxes have 5gal plastic containers of K-1. The right hand box is all K-1 Kerosene (~90gal) in 5gal jugs and these are the spill over. Then middle 2 x boxes have 14 x 40lb propane tanks. The misc box has gasoline, butane, small propane.What are those brown cardboard box looking things next to the propane tanks?![]()
Where did you get the boxes, I need some for my propane.Thank you!
I used 200gal boxes as they fit 8 x 40lb propane tanks nicely - https://www.amazon.com/gp/product/B0DD3ZFP3X/ref=ppx_yo_dt_b_search_asin_titleWhere did you get the boxes, I need some for my propane.
Holy mud pies Batman!So... i get a call from a condo association i work at.
They got dinged on their fire inspection, all the lower meter box covers were on the ground in the power room in A building.
I go in there, and... i flat out said no way i would reinstall the covers until they made the room safer.
It is a small bunker celler with a concrete floor, it has a single sump pump in it to handle water.
The mud line on the wall in the room stops at the top of the stairs...
The pump alarm is disconnected.
The room has TWO cuts into the wall to allow flooding into the electrical room where the pump is.
The lower set of power meters, AND THE MAIN GUTTERBOX WITH THE PRIMARY BUSBARS all are below the mudline.
All new meters recently installed... i guess the old ones failed due to mud and water...
All the 60A main pulls and meterboxes caked in mud.
Problem #1The pump alarm is disconnected.
Problem #2...The room has TWO cuts into the wall to allow flooding into the electrical room where the pump is.
