If it were me I'd throw a couple braces underneath about midway up. That's a pretty long span and if the unit has any weight at all there's a chance that one of those 2X4's won't be happy with the loadForgot the best part - custom made slide for the ramp!
Zip-ties might hold the HVAC equipment to the slide, I hope.....
Grab some of those surplus chinese factory anti suicide nets can catch him nice and safePsst local FD and ambulance, we need to pre-stage a unit out at this location... going to be an old dust farting Son of a gun on the ground in 5...4...3...2...1 CONTACT and I am not talking about close encounters of the third kind... steven spielberg be damned...
I considered that, have the wood available to brace it.If it were me I'd throw a couple braces underneath about midway up.
The only way to do chickens IMO is Premier 1 electric fence net. No fear of racoons tearing through your fence. Can get it in 42" or 48" tall options and 162ft long sections. No more ground predator problems except Bobcat/Mountain Lion and in theory Coyote could clear the 48" fence. And we add a couple of geese (african or chinese) to handle bird predators. Saw a hawk come gliding out of the woods across the fenced area, the goose took off flying ground effect squawking towards the hawk.The last time we did chickens at the old house my daughter had a pet rooster she named Charlie. She made a pet out of him. Then one night racoons ripped thru the fencing on the pen he was in and ripped him apart. So after that I want to try the dog fencing on this new setup.
I did the same thing getting my panel on the roof .. I just did not have the platform .. works like a champ .. (your is better construction then mine.. lol was spare wood for me .. )Forgot the best part - custom made slide for the ramp!
Should have got some bifacials, then you could generate power at night!This was a low effort one.
String lights.
Under my solar panels.
It looks nice, I think.
I was actually wondering what bifacials would register that as.Should have got some bifacials, then you could generate power at night!
/s
22 watts. So that's 2.64 watts regained. But will the string voltage reach 150v where I need to activate my mppt?Take the wattage of the LED string.
Multiply by .12.
There you go.![]()
.that's 2.64 watts regained. But will the string voltage reach 150v where I need to activate my mppt?
Mine get 21v from street light and 29v from full moon .. lol .. led just don’t have the mmmphI was actually wondering what bifacials would register that as.
Yep those volts are nice. Too bad the amps don't follow alongMine get 21v from street light and 29v from full moon .. lol .. led just don’t have the mmmph
Yeah amps would be nice…but that’s a big zippo on the amps…Yep those volts are nice. Too bad the amps don't follow along![]()
I'll have to get another picture, but I was so pleased with this weather station, I bought their lightning detector and an enclosure for it, and mounted it to the pole.Maybe not that interesting of a project, but I bought one of those personal weather stations a while back on sale, and finally got around to installing it.
I used my two-stroke auger and sank a pressure treated 4x4 about 30 inches down, and I tried (for the first time) that expanding foam stuff as fill, rather than concrete. I don't think I'd ever use this stuff for anything load bearing, but for just holding my little weather station it seems plenty sturdy. The foam was super fast, I think I was done with the whole job in like a half hour. Found some cheap pole mount on Amazon (clearly not designed for a 4x4) and set it up.
I'm currently just using Ambient's cloud service, but when I have time I will probably set it up with MQTT to feed directly to HomeAssistant and then detach it from the cloud. Based off some quick searching, it looks like there's projects that can do that just fine, but I need to research them some more.
I built everything from scratch since the late 80's up until about 15 years ago. Then I bought alienware machines. Never looked backSometimes it's just the stupid little victories...
I've been upgrading the same computer since 1992, i.e., I've never purchased a whole computer after that, but obviously everything has been swapped out multiple times.
It's basically the cadillac of 2012... an AMD FX-8350. At one point, it was liquid cooled - not for performance but for quiet.
TWO liquid coolers failed over the years, and I just stopped caring, so now it has a traditional cooler on it. A couple weeks ago, I noticed it was running pretty hot, throttling itself, and the CPU fan was working hard and loud.
My first solution was to use AMD Overdrive to cut the CPU frequency in half to 2GHz, so it didn't cook itself. Temps improved, but I really noticed the slowdown.
Tonight, blew the whole case out - SO MUCH DUST - and discovered two of the 120mm inlet fans needed lube. Pulled the CPU cooler and discovered dust packed into the fins immediately below the fan. This stuff was dense and hard to blow out... covering almost the entire area between the fan and the cooler fins. Fresh paste in between the cooler and CPU for good measure.
With everything back together, CPU temps are CRUSHED to just above ambient. At half speed and choked flow, my idle temps were 20°C higher. Can only conclude the CPU cooler was little better than passive with the blockage between fan and fins.
All this really means is that I'm more confident that I'll make it to the Win 10 end of support in October... Don't meet Win 11 hardware requirements...![]()
Loved windows 7 but HATED windows 8.I'm still running windows 8.0. Best os. no forced upgrades or patches. Everything works.
