My new battery will be here next week, atm I'm using 2 12volt lead acids (nothing special). Today I finally put a real load on it and this is what the solar charge controller is putting out, which I assume might be about max. Its four 410 watt bifacials with open circuit voltage of 49 vdc and around 10 amps (9.65) and my vmp is 42.50 volts.
So, what wattage are my panels putting out?
With the new battery I also have a growatt 3,000 watt all in one coming in to replace this one, which will go elsewhere....
