patsfan1986
Schneider XW Pro Inverter hooked up to 4 12vdc 200ah series config batteries.
Been on the phone with Schneider for about 4 hours and we still cant figure it out.
When the XW Pro starts bulk charging... the voltage climbs..... 56....57....58..... then all of a sudden the voltage will jump to over 65+ volts hitting the High Battery Voltage Cutoff.
I keep adjusting the bulk charge rate from 57.6 all the way down to 56 .... Ill adjust the charge current from 40 -> 20 -> 10 etc.. and no matter what I'm always hitting the voltage cutoff.
Spoke with 2 Schneider techs via phone ; been tweaking the battery charging settings but still not having any luck.
Any ideas on what may be causing this?
Appreciate any advice.
