PopUpSteve
Sorry if I missed it but can all 3 12v output ports be used simultaneously?
Relatedish, but has anyone found the 7.9mm x 2.5mm "8mm" plugs used on so many of these power stations in a panel mount form? They're a dime a dozen for 2.1x5.5mm panel mount / chassis mount jacks, but I'm yet to find a single offering for 8mm with all sorts of google queries. Been looking for well over a year, figured they'd be plentiful with how many mfgs use them. I'd hate to have to cannibalize an 8mm extension wire and epoxy in to a hole.
I made 2 cables that plug into my Jackery and telescope for about $13 each.
Here is what I did:
cablesandconnectors.com
Philmore
4.3 (1.4mm C.Tip) x 6.5mm Inline DC Power Plug
Item# 35380 (253 ) $4.99 USD 2 $9.98 USD
This is the connector for the Jackery 12v ports.
Check out. Found this on this site from Zilch. As a recommendation. Their tech-support is good too. For AC50s it’s not 3 pole but maybe workable and they have a panel mount companion.Relatedish, but has anyone found the 7.9mm x 2.5mm "8mm" plugs used on so many of these power stations in a panel mount form? They're a dime a dozen for 2.1x5.5mm panel mount / chassis mount jacks, but I'm yet to find a single offering for 8mm with all sorts of google queries. Been looking for well over a year, figured they'd be plentiful with how many mfgs use them. I'd hate to have to cannibalize an 8mm extension wire and epoxy in to a hole.
8mm 2 pole power connector
From Newark NJ. Electronics
Lumberg 1614.07 dc7909 8mm male 2 pole 10amp.
1636.07 female panel matching 10amp
I hope to wire the ones I received and convert them to a three pole for my AC50s. But I may end up with a a lenovo ac Charger that possibly would support power to the center pin and the inner shell for my battery.
Yes, the Philmore 4.3 (1.4mm C.Tip) x 6.5mm Inline DC Power Plug from cablesandconnectors.com maintains a good connection, even with the heavier (thicker?) wire cable. Very happy with the cables I made. One of cables powers the EQ-G mount, and the other cable powers the Starshoot G-10 color imaging camera.Thanks for finding these. Have you tested them and found that they maintain their connection as well as the original plug supplied by Jackery? There were some issues with the center pins of some other plugs not being long enough keep their continuity when jiggled.
The description says the plug is found on laptops. I may have to start looking more closely at all the old power bricks I come across.
