New member, and reading a lot about the 277/280Ah cells from several mfgrs and suppliers. They seem too good to be true.
I have a space 15l" x 13"w x 10"h to fill for a 12V bank. I can fill it with 12 100Ah Winston cells, or 8 280Ah cells. The 280Ah cells would provide nearly twice the capacity, in the same volume of space, and would weigh only slightly more. What is it about the chemistry or physics of these cells that allows so much more energy density by both volume and weight? Also, I have seen some 240Ah cells that are the exact dimensions and weight as the 280Ah cells. Odd. Are these 280Ah cells going to have the longevity as other cells, or is the mfgr (or a distributor) squeezing more into them than they should?
My application is a boat. Durability is very important. They will be subject to vibration, sometimes intense. Also, occasionally in rough seas I might be "knocked down" which can be very violent, almost like a car accident. They will be shaken and tips on their side. I can mount them securely so they won't break loose and wont' physically break their casing, but I need a cell that is sturdy internally. Assuming solid mounting, would the 280Ah cells hold up?
I will be sailing remote locations, where it simply will not be possible to obtain parts or replacement. Carrying an extra cell or 2, and an extra BMS is reasonable. But primary concern is that they don't fail. I had been looking at expensive drop-ins (battleborn) but I am hoping to get at least 300Ah in my space, and 300Ah of drop-in won't fit.
