when does a battery do more harm than good?
Tariq0101
I have a small 12v batter bank using 3 batteries connected on parallel:
100 Amp, 3 years old
120 Amp, 2 years old
70 Amp, 1 year old
I basically just add whatever 12v battery I get my hands on on parallel.
and now I'm thinking of buying a 4th battery because winter is coming (not a game of thrones reference)
but the 100 amp 3 yo battery is worrying me, I'm not sure that it's holding any charge but I worry that some energy is wasted there on internal resistance, is there any harm from keeping it or should I remove it? and if I remove it and found that it's still holding some charge, is there a way to calculate if that charge is more than what the battery wastes on internal resistance?
Separately test all the mix matched batteries at least once a year.
Fully charge and let rest disconnected 48 hours and check voltage Is good. Verify full charge with a hydrometer. If still in doubt have it load tested.
While in use the parallel is fine. If you store them without a float charge I would separate them.
Some will be here shortly to say you should never mix different age batteries, even in parallel. But I have been doing it for years. I have one battery with a 4 year difference.
But as posted above, just check the specific gravity on all of them, Maybe even load test them all separately.
You can use a Battery Analyzer to get some idea of the battery condition.
But you are correct. If you have a really poor battery, it will be turning your charging power into heat and gas and prevent the other batteries from getting a full charge by holding the voltage low. So I would separate and test each one.
I question the ability of that sort of meter to accurately test a battery. How is is loading it more than a few amps? IMO one of those simple resistor based testers would be better than that.
While a hassle to have to take them somewhere, places like Walmart will put it on the good analyzer and print out the results.
I questioned it too. It's not loading up the battery, but doing a resistance and other checks. There is more expensive models that do the same thing. When comparing it to other "professional" testers at the shop I worked at, the little HF was surprisingly accurate.
So if the battery didn't pass the load test I should get rid of it?
As long as you are sure it was fully charged when you did the test.
When any of my batteries start to look "tired", I pull it out of my bank and put it on a stand alone charger that can do equalization. After maybe 5-10 cycles of that, it usually comes back to life. If not, it gets replaced.
