larrylwill
- Aug 22, 2021
- 92
I set up a 280AH Lifepo4 battery in my Motorhome, I added a new Inverter, AC charger and Shore power AC auto switch. Everything is working ok. I have a 250A under hood Gen separate from the A standard alternator and a Volts start which has the lithium module. This charges the house battery when boondocking is it gets too low. I do not know what voltage.
I keep the MH in the garage plugged in to AC The charger is only 10 amp for LifePo4 or AGM. My question is at what voltage should I start the ac charger? When I park it its full, but as the days wear on the battery discharges slowly and the voltage drops. At what voltage should I set the charger to start a charge cycle. In other words How Low Should I go?
