Where to buy 2/0 wire?
LVLAaron
Need to run a pair of wires from the front to back of my camper (20 feet)
Where is the best source to buy 2/0 wire?
Rich585
I live in a rural area. Anchor cable from Amazon. If nothing close by. I am using in boat reason for tinned but not crazy expensive over welding cable
chrisski
Photon Sorcerer
My local Hardware store either Lowes or Home Depot has THHN cable. A bit stiffer, but available right away. Otherwise its Amazon or Wireandcableyourway.com.
That’s quite the run of wire for a camper. Are you putting this in any kind of conduit or split loom?
curiouscarbon
Science Penguin
Have had good experience with this source for about 50ft worth of thick stranded conductor.
It usually comes with some fiberglass residue on the outside of the insulation. So I tend to wipe that off.
LVLAaron
I'm adding a 400ah lithium pack and want to have it in the rear storage area instead of up on the tongue of the trailer. I also don't want to do to much hackery to the factory wiring.
The frame has a set of holes through it. It will be loomed and run through grommets
iu
Firstascent
I just purchased some Ancor 2/0 wire, if you want some tinned and fine-strand wire that’s your best bet! If you want great wire fine strand and bare copper get some welding cable.
Any larger I like fine strand since it will help with flexibility
