luckybadger
- Aug 20, 2021
- 4
My understanding from talking to others is the V2 takes a different AC adapter. It uses 24V, 12.5A to achieve 300W. They basically cut the voltage in half (48V->24V) while doubling the current (6.25->12.5). Again I don't have a V2, so I can't confirm the numbers and I've gotten them from others. Your results are consistent with a V1, which uses 48V, 6.25A. It will not take more than 6.25A.Very interesting… i think the V2 also has slightly larger capacity than V1. My 1500 says it has 1488wh but their website spec is over 1500wh. So V2 can take more current, but I assume max voltage is still 48v given the AC adapter still is the same. So while max power is still 300w, there is more flexibility to get to 300w since v2 allows 12A while v1 max at 6.25?
I have also observed that my jackery 1500 doesn’t seem to take more than 6-7A of current. I tested this with a 480V 12-48V variable voltage supply and noted accepted power increase with voltage, with the jackery not drawing more than 6A, I had expected it to have steady power and just pull more A when voltage is lower. The only exception is when the input voltage is around 12-14v, where it seems to draw more, maybe there is exception when it think it is being charged from a car cigarette adapter. I will need to do more experiment to check.
I connected a canada solar 315 panel (Vmp 33v, Imp 9.5A) and am surprised that the max power I got was around 190W. This now make sense if the max current is 6A.
I had purchased the 1500 with the idea of pairing it with one of their SolarSaga 200's. When I used the 200 with the E1500, it gave around 115W max. It was returned to Jackery, but it's consistent with what you'd expect for a 19V panel i.e. 19V*6.25=118W. A V2 "should" work well with the 200, since the 200 outputs a current of around 10.5A, and the V2 can handle up to 24V, 12.5A (if the numbers are correct). I decided to try out the Rockpals as it's a much less expensive solution than going with their panels/finding a workaround with them. While I've found their customer support bends over backwards to work with you, it can be a little tiring because they're overworked, in a much different timezone, and it can sometimes take multiple email/waits for them to understand exactly what you're requesting. The only downside to the Rockpals that I can see is it's only IPV4 and the junction box isn't water resistent, so I'll need to keep it out of the rain, and I'm OK with that.
Also, don't use the Rockpals with a V2 in 36V mode; the V2 can only handle 24V. If you use it in 18V mode, you'll get a max of 100W out of it.
