Andrew20252
I'm planning a 25 panel 10.5kw grid-tied roof mounted PV system on my home in Tucson, Arizona. Electric company is Tucson Electric Power (TEP). Will be using a Sol-Ark 15k inverter to make whole home backup simple and either the Homegrid Stackd series 19.2kWh battery (4 batteries) or four Pytes V5 batteries.
My primary question - where should I locate the inverter and batteries?
My main service panel and meter are on the outside of my living room on the north side of my home. I would really like to locate them on the exterior wall with the panel to keep things simple. It is relatively sun exposed during the summer and we average 106 degrees F everyday, all summer long. More difficult option is inside my non-insulated garage, which still stays relatively cool, but would require a 50-60 foot cable run between the inverter/battery and the panel and back again.
Pytes V5 temperature limitation: charge 113 deg F (45 deg C), discharge 122 deg F (50 deg C)
Homegrid Stackd Series temperature limitation: charge 113 deg F (45 deg C), discharge 140 deg F (60 deg C) - also see 131 deg F (55 deg C) in some documents
Homegrid warranty limitation "damages caused by or resulting from excessive heat (temperatures higher than 113°F (45°C) are considered excessive heat)"
I was considering the Pytes due to the Homegrid excessive heat warning and it has a much more robust outdoor enclosure.
I know the electronics and batteries will last longer the cooler they are, so do I just need to bite the bullet and put them in the garage or is there a way to make them work outside?
Thanks for your input
