It all depends on the logic in the smart shunt.Didn't see in mention of chatter in the smart shunt specs. Do you think it might be an issue? Maybe an SSR?
I got a hunch that they will talk to you if you call them.Yeah, thats the one I have ordered...not much info out there on them though.
That is an interesting peice of kit. A shunt with HI/Low disconnect. I'll have to keep that in mind for possible future builds. I just wish it had a display that would allow me to see SOC at a glace. (I like being able to glance at a meter to get the SOC. Everything else is read seldom enough that pulling out a phone is fine.)This is the link https://www.thornwave.com/collectio...tor-dc-power-meter-with-integrated-500a-shunt
I would not be surprised if it has a hysteresis feature.
It has a bluetooth app.That is an interesting peice of kit. A shunt with HI/Low disconnect. I'll have to keep that in mind for possible future builds. I just wish it had a display that would allow me to see SOC at a glace.
It does.(I like being able to glance at a meter to get the SOC. Everything else is read seldom enough that pulling out a phone is fine.)
What I did not see in the description is using it as a charge controller. However, I recon it could be used as such. It looks sophisticated enough that it probably has both a High voltage disconnect as well as a recovery voltage.
The company also offers high current SSRs.With the design shown, it would connect the turbine to the battery till it hits the high voltage disconnect. When that happens, the turbine would be switched to the dump load till the battery hits the recovery voltage. That would minimize chatter, but you still have a mechanical relay switching on and off.
Those are 'Interesting'The company also offers high current SSRs.
