RyanNicholas
- Dec 18, 2020
- 89
Hey, so I have a 4s lifepo4 280ah (EVE) setup that currently doesn't have a working BMS. I originally got a Daly 200a Smart BMS with the whole package (from Alibaba), but a few months ago it was screwing up so I retired it and got a refund. I've been running my system without a BMS, but with my charge controller set to max out at 13.6v, just to be safe. But I want to put a better BMS in the system, so I actually have one like I should (and so I can safely hook up the battery isolator from my van to the battery so there's another way to charge it when it's cloudy and raining).
I've been thinking of getting the Overkill Solar 4s unit (there's a backorder wait still), but I've gathered that there are different pros and cons for different BMS's depending on what kind of use your battery gets. I'd like to get one that doesn't cost several hundred dollars oh, and that has features like Bluetooth connectivity and low temperature disconnect, in case I am in sub-freezing temperatures again with the van. High temperature disconnect would be nice as well, since I often seem to find myself in rather hot climates. I'd really like to have a fully functional system that is safe to take into hot summertime places as well as cold wintertime places. Do you think the overkill model is my best bet?
Not sure how much this matters, but my biggest load is a 60 liter 12v fridge. Other than that it's pretty much lights and phones, occasional laptop charge, Etc. Plus the maxxair fan in the ceiling, and an additional fan in the summer or small diesel heater unit in the winter. Even though the faulty BMS I had was a 200-AMP model, I'm sure I probably don't need something that high and it would be fine with the overkill unit, which I think is 120 amp.
I'm thinking the overkill might be best but I'm not sure if it has a high temperature disconnect. Any advice is welcome. Thank you!
