Sabre602
Putterer/Tinkerer
OK, I've got my two 12 volt, 280 Ah batteries built, each using a 120 amp Xiaoxiang BMS (JBD branded RadioB Tech). They'll be wired in parallel on my boat, supplying and charged by a Samlex EVO-1212 inverter/charger. (We will also charge from a Kisae DMT 1250 Abso DC-DC charger from the alternator with built-in MPPT solar controller from future panels that will be installed later). I plan to use 10% to 90% SOC as our useful range in order to promote pack longevity.
The Samlex has a rich variety of programmable options, and I have the remote panel that gives access to this. With much help from you all, I have set my initial voltages for inverter function, but now I'm looking at programming the charging profiles to use when we're at the dock, tied to shore power. During trips we'll want to put the batteries at a high state of charge when we occasionally stop overnight at a marina for shore power. When at our home dock, we can set the voltages to keep the batteries happy at a middling state of charge...50% or so. An SD card will allow us to quickly swap programs for these two different purposes.
OK, I've set the battery type to lithium, and now have several choices for charging profiles. They are as follows:
3 Stage Type 1
Bulk Stage at constant current until desired voltage is reached, then
Absorption Stage at constant voltage for a programmable length of time, then
Float Stage at constant voltage. Reset to Bulk Stage after 10 days in Float or with voltage drop to programmable parameter.
3 Stage Type 2
Absorption Stage at constant voltage until current drops to specified amperage, then
2 Stage Type 1
Absorption Stage at constant voltage for a programmable length of time, then switches charging OFF
Reset to Bulk Stage after 10 days or with voltage drop to programmable parameter.
2 Stage Type 2
Absorption Stage at constant voltage; this is a de facto Float Stage.
So what does the collective wisdom say about these options? Will one be preferable for routine charging to 50% SOC when at our home dock and a different one preferred for a high SOC during trips? What are the pros and cons of the different profiles?
Thank you in advance for your input!
3 Stage Type 1
3 Stage Type 2
2 Stage Type 1
2 Stage Type 2
