Powderskier
Hi all. A bit of a long post but please bare with me. I've been running a Growatt SPF 12000 DVM MPV inverter since last fall. Problems occurred within 3 weeks. One if the charge controllers burnt up. Signature Solar sent me an 80 amp growatt straight away. So this charge controller is an add on going direct to my bus bars on 6 LifePower eg4 batteries. Since then I have bought 3 more 80 amp growatt controllers. Each controller looks after 10 450 watt panels 5p2s.
So 30 in total of 13500 watts.
I'm in southern Mexico where receiving anything is time consuming and tedious, plus getting anything electrical is not easy. With that being said my main board, caps transistor heatsink circuit board fried on the inverter. After many calls I received a new board on warranty. It has been about 2.5 months and I'm getting power fluctuations again. I can run the inverer for 2.5 to 3 days then have to go to genny for at least half a day then I can go back to inverer for a bit.
The problem is water condensing on the inside right after the bottom fan. It then short circuits between the board and bottom capacitors. I asked signature solar if I could brush epoxy on the boards to seal the area they said no that I need to put a dehumidifier in my room.
So I'm looking at replacing this inverter with a Victron multiplus 10000 or 2 Schnieder Context 6848 pro. Both will take a week or 2 to get to me or do I get another growatt 12000 save the money (I've spent probably $1200 in gas) and say I got a Friday afternoon model.
Humidity is high down here but IP20 enclosure states 100 % non condensing and I'm certainly in a good room. Will another brand result in the same problems. When working the Growatt 12000 supplies enough power, although more would be nice. I can at least stack the other models.
I will be off grid for many years to come so that is putting my mind more to the Schnieder.
Thanks for any suggestions or help.
