So technically no cons just practically. Got it thanks that's what I needed to know.
Not exactly, like someone implied in an earlier comment (limo vs dumptruck) it all depends on your use case. Its not a matter of better/worse, its a matter of priorities and use case.
For a cabin I see little reason to consider smaller panels if you use an MPPT controller. Larger panels offer more watts per KG and slightly more watts per square meter usually, require less wiring, fasteners, etc, will work with a single planel can work for 12 or 24v systems, and offer a cleaner look.
For a mobile system, smaller panels are (at least theoretically) stronger/more resilient, more versatile in their placement, easier to work with, more modular/reconfigurable as your system develops, are not a single point of failure and potentially more tolerant of partial shade if configured correctly for that goal.
Larger panels offer more watts per KG and slightly more watts per meter usually, require less wiring, fasteners, etc, and offer a cleaner look.
But why stop at 195w, why not go with 2 300w or 350w residential panels, there is sometimes considerable cost savings at that size.
