CharlesK
I am building two 16-cell, LiFePO4, 280AH, 48V DIY batteries. They will be part of a system that will include two Victron Quattro 48-5000 units (configured for 240V split-phase), some solar panels with MPPT SCC's, etc. The system will be installed in a motorhome. I will have connections for shore power. There is also a 240VAC split-phase diesel generator already on board. The goal is to supply the batteries with solar as much as possible, with the generator as a backup charging source. Shore power may be used when the batteries are low, the generator noise is not welcome, and shore power is available.
The question is BMS selection. I need some help.
I have narrowed my selection of BMS's to JK-B2A20S20P units. These have 2 amps of active balancing and 200A max of charge and discharge. I found a supplier on Ali for these. So far, so good. However, they offer three different versions of this unit.
JK-B2A20S20P
JK-B2A20S20P-CAN
JK-B2A20S20P-Heat
All three have Bluetooth communication and software for Android and IOS. The second has a port for CAN-BUS. The third has a connection for a heater pad to warm the battery. At least that is my understanding.
I believe that the Victron equipment will NOT converse with the JK BMS.
Based on the above, I am thinking that the CANBUS option is not what I want. What is the purpose of the CANBUS on the JK-BMS? What other equipment (obviously not Victron) can it talk to?
The HEAT option appears to be useful. Our future travel plans include the Carolinas, Georgia, and Tennessee in January and February (coldest winter months). Outside temps may occasionally hit the single digits. The batteries and the Victron equipment will be in an enclosed basement storage area. There used to be a bit of heat from the propane furnaces directed here. However, I removed the furnaces and the entire propane system. The main areas of the coach will be heated with a combination of electric floor heat and minisplits. I guess I could add some electric floor heat in the storage bays to keep all of the equipment happy.
Does anyone have any thoughts and/or experience with either the CANBUS or Heat options with JK-BMS?
Thanks!!!
JK-B2A20S20P
JK-B2A20S20P-CAN
JK-B2A20S20P-Heat
Thanks!!!
