I have designed a system that consists of very little. I have 2 100w/ 5.6A small solar panels in series. So i am wokring with a 24v/5.6A solar array to power a few items... this is what I am having an issue understanding for some reason. On my MPPT charger, I am connecting my load, which has a max input and output of 1A, (I am not using an inverter). This is simply a POE switch. That POE switch will be powering only a couple of things, maybe a camera, a wireless bridge, etc. All running off of POE supplied by the switch.
Calculating the cameras and bridge separately, it would be approx. 55 watts. But the way I see it is I shouldn't worry about what each device is pulling if they are being powered by my POE switch. Am I correct in assuming the power that I should be considering in my calculations is just that, the switch? (I believe the switch's max output would be my max power draw, 24v @ 1A = 24WH
If not, please let me know and thanks in advance for any help provided.
