jamiegreen
- Nov 8, 2021
- 182
Currently I live completely off grid with a 2kw solar array (limited to 1.6kw by cc) and 6kwh of lifepo4 with diesel geni backup. I'm finding now coming into summer that when I'm out most of the day my batteries are constantly sitting in float and I'm wasting potential solar power. I've got a 250l hot water cylinder that supplies my home, at the moment I'm heating this via LPG, the 3kw element is too much for my victron 3kva inverter to run for long periods.
I had a choice of a 1.5kw or a 2kw element, I bought a 2kw element with the idea that it could turn on at say 98% battery and off at 80%, which would let the battery drain slightly and charge back up instead of sitting full all the time (not great for lifepo4?).. but also I don't want to degrade with too much cycling, but would cycling the top 20% really hurt it at all?
If I swap it for a 1.5kw element, taking into account they usually don't draw as much as they claim + inverter inefficiencies it may draw around the 1.6kw mark, but would have very little if any drain on the battery.. not sure if that would be better or worse.
Any opinions appreciated on which would be a better wattage element.
Thanks
Thanks
