Which48V/60V LiFePo batteries are worth buying?
GoetzSaCebu
As I live in the philippines its always difficult to get reliable tech here locally.
That way I need your recommendations for E-Bike/Trike batteries that usually have 48V/20Ah or 60V/20Ah or more Ah.
What I look for is that they can replace the usually used LeadAcid batteries (same size to fit compartments), but have a reliable BMS build in and best a Bluetooth connection so the user can check the battery with his App.
Which one (Links would be nice) can you recommend on either Amazon USA or Alibaba?
Thank you.
As long as the store you choose is reputable and has a large transaction volume, it is basically no problem. The only thing to pay attention to is that you should not buy too cheap LiFePO4 batteries, which is likely to be a trap.
