Who's in the UK and Ireland?
Roly
Maybe the 24v one can be adjusted all the way down to 3.5V but it seems a bit of a stretch.
Yeah that's the plan. Because it's 0-30v I should be able to reduce it to 3.6v for the top balance and then upto 28.2 for the hookup charge.
squowse
Sorry I don't know what I was thinking - the 24V power supply won't be able to do your top balancing. You'd need one about 3.5V of course. I've got a 5V one here I'm going to see about extending the adjustment to 3-3.5v by replacing the variable resistor used to control the voltage. I've seen it done on a smaller one on YouTube. I'll find out I suppose.
I could only get the voltage down to about 4.5 before it went all the way down to 2.9 and stayed there until switched off and on again. I assume it;s a feedback loop or something. The video I saw he took it down to 4.2 but his started lower than mine.
Annoyingly it did seem to work at first but I think I didn't notice it was stuck at 2.9.
Roly
Does it have course and fine adjustment on it or just the one?
squowse
This is the kind of thing you could use for 24V charging - 60A (1500w) so a decent current. You don't want to messing about waiting days for them to charge. They do have smaller ones.
squowse
it's just a little screwdriver adjustment. I desoldered it and connected a bigger resistor to lower the voltage. Didn't work. I'll get a 3.3V volt one. I didn't see them originally. Thought I could adjust a 5V one.
Roly
I think these are just fixed power supplies though so couldn't draw more than the 24v and thought the voltage needed to be higher than that to be able to charge fully (28v)
squowse
They can be adjusted a bit plus and minus. I'll get a 12V one out tomorrow and see the max voltage it will do.
Actually you're probably right - these are easier to adjust downwards than upwards in voltage. A 30V would be ideal if you could find one.
squowse
There are 27V ones. Biggest I could find it 1500W. They will adjust up in voltage about 10% typically.
Roly
squowse
as you say 30v would be ideal but they jump to 36v
I did find a couple 30V ones but pretty sure it will go up 10% at least. 28.8V would be plenty I think
here's where I asked about it before
Roly
Perfect thread, answered all my questions. I'm going to use the 30v 10A bench PS that I have for the top balance and see how that works for mains hookup charge. If it takes too long then these PS you suggested via a PWM will smash it. Much happier about the setup now. Brilliant
Roly
Apparently it's NOT that straight forward. Did you read this thread about current limitation?
https://diysolarforum.com/threads/c...-without-current-limitation.17042/post-195181
Steveb
I am in the UK and I ordered 4 x Lifepo4 280ah cells from Basen on Alibaba on 10th November 2020 and I am still waiting after 16 weeks. I don't know whether to cancel the order and get a refund or carry on waiting. If I cancel the order I don't know where else I can get them from in a reasonable time. Any thoughts?
squowse
that's no good. can they not give you any tracking information? I managed to get the ship name you can see it make it's way across the world using the maritime traffic trackers.
squowse
whereabouts are you Steve? Maybe someone can swap you 4 cells till you get them replaced? 16 weeks sounds like they've got lost / damaged to me. I'd be looking to start again.
Steveb
I'm near Devizes at the moment but I live on my narrow boat and will be moving as soon as lockdown allows.
Steveb
They gave me a DPD tracking number which just says they have the parcel details but have not yet received the parcel. When the supplier checks the tracking it shows the parcel was in Germany on the 24th December but doesn't show anything after this date.
squowse
yes I've got a courier tracking that doesn't go live till it lands in UK. Sounds confusing then - if DPD are telling you they haven't received it but some other tracking has recorded it in Germany. Presumably it came by train? After 2 months I think they'll have to accept it as lost.
