RyanNicholas
- Dec 18, 2020
- 89
I have had my 4 280ah EVE lifepo4 cells hooked up to a 10 amp bench power supply for over a week now, and the amperage still has not dropped. They've been connected for about 10 days. On two (or possibly three) different nights, the power supply was turned off- but it has been on day and night the rest of the time. I've been trying to fully charge and top balance the cells; they are connected in parallel and to the charger as shown in the picture. I've been using these cells (assembled in series, of course, as a 12 volt battery) for about 6 months - but I never performed an active top balance on them ( I was told the "passive" method of simply connecting them in parallel overnight without a power supply would work, but have recently come across mixed messages about that), so I took the opportunity while having access to a shop to connect them to this power supply but I thought it would only take four days at the most for them to completely top off. The cells had recently reached a very low SOC, after little to no solar juice in a cloudy and rainy climate for several days. But even at a 0% SoC, it should not have taken more than 4.5 days to reach full charge. So, I'm at a loss here and I'm sincerely hoping this is not indicative of any sort of damage or problems with my pretty much brand new battery cells. Help?
I just disassembled everything and tested the voltage on each cell. They are all reading from 3.35 to 3.37 - a slight variation, which seems to suggest the intended balancing was not effective. Any thoughts or advice on all this are welcome. Thank you.
