Why buy a 100ah server rack when you can DIY a 280 or 320 for $200 more?
homeshow
Dayton Tn
Signature solar is offering a EG4 48V 100ah server rack battery for $1200.
You can build a 48v from 3.2v 280 or 320ah cells with BMS. It's maybe $200 more. Plus with the almost complete shutdown of E-vehicles production. Battery and other parts could see further price drips. Or there are E-vehicle cells for cheap.
Here is the EG4 @Signature.
Or a 280Ah rack battery for $250 less.
Well that is annoying. I have V1 on the truck coming Thursday with only a 5 year warranty and I bought the comm hub.
If you can utilize the government 30% tax credit I think the quality of the build is hard to beat with the welded busbar construction the Nader disconnect breaker also nice to have the closed loop RSD communication disconnect system that turns the Breakers off in the event of an emergency and I think the EG4 Power wall batteries are the better deal more slightly money per kilowatt but you get added fire suppression for code compliance plus 600A bus bars and built in heaters for a cold temperatures and better warranty.
I'm not familiar with the government 30% tax credit if you have any links that would be great.
I just keep buying the 51.2v 100ah chins with bluetooth at $790 or less when they go on sale from time to time with free shipping. Working out nicely so far.
Many people just don't want to hassle with figuring out how to wire a BMS, investing in the tools, top balancing, etc. They want something that just plugs in and works. Plus, you get a lot of features in the pre-built that some people want like communications and a fancy screen and such.
Myself, I have no desire for anything fancy or high tech, I just want a main breaker, a positive bolt, and a negative bolt. When I build mine out I'll add in the features that I want like an internal Class-T fuse, cooling fans, heater, and a shunt. I figure even if I pay for USA stock from Docan, I can build a 304Ah for less than $2k with only the things I want in them. But then again, I enjoy building batteries, so I'm weird. ;)
And it gives me an excuse to break out the welder again.
Keep in mind that prism prices have dropped significantly in the last year or two. I paid $800 just 18 months ago for my 100ah batteries but they're pouch cells and take up much less space as well as having higher density and lower IR... But now I'd love to include one 280 to 340 per week just because building prism batteries is fun and not a waste of money... It will carry me through the one month when I may touch the grid this winter the build is addictive behavior... Hi I'm Wessss77 and I'm an addict :)
Build a 14 to 16kWh battery per week? Nice :)
Get something with comms for $885:
I might buy one of those for the new system in the other house. I don't run comms. Can't see much of a purpose in it. The battery's bms protects itself and I don't have all of the drama the comms folks do when a battery gets ticked off :)
Where and when? Thanks
So check these out they're 24V and you'd have to run a balancer but they're 280 Ah x 2 for less than $1000
Just casually throwing out 'bouncer' in a thread pretty much sells the all-in-one for most people. Please explain what that is. Also remember many don't know what a BMS is, but they do find out once they drain their battery for the first time, and then find out their LiFePO4 has a BMS inside of it.
one of the few on here who has chins. I do as well (12V, no bluetooth). With your chins are you just adding more and more in parallel? Thanks
Nobody said anything about bouncer that was about half baked :fp2
I think the fact that no one has said here is how you build a DIY battery. You will need these 3-4 tools. Here's links to those tools. You will need a place to store them. here is a link to an enclosure. You will need to buy these cells. here's the link to buy these in USA. You need to buy a BMS. Specifically buy this model J/K at this link (or more links, as they seem to be forever out of stock). Buy these bars to go between the batteries. Here is link to these bars. Here is a map of how to lay them out inside the box above. Here is the charger to buy to balance the cells. here is how to use that balancer. Here is the time it should take to balance each cell. In 10 days once everything is balanced, now assemble. Now wire the bms like this (which wire goes where). here's the conductors you should purchase. here's the crimper. here's the lugs. Oh and here's a bus bar I recommend to connect this battery to. Oh and here's the breaker you should use before connecting to your bus bar. And a kill switch you recommend. And oh wait - a meter for this new battery you made. And before you do all of this, this is the space you will need in your garage, living room, kitchen counter, shop to assemble/charge, and the size you will need once it is all together. The rest is up to you.
That is why I believe DIY is less popular/common. Plus warrantee. Plus what to do if individual cell is bad or won't balance or whatever. I think buying something with a switch, warrantee, and a store to back you up is worth something to most people. Which is why you don't see too many individuals making their own automobiles vs. buying one, for example. I think the cost per kWh also goes down the bigger the battery you buy. Isn't a powerwall (Tesla) 7.2 kWh or something for $8,000 USD? I may be wrong.
I want to do a battery DIY, absolutely. But the time it takes and frustration of learning new things at an older age is prohibitive for some.
