iamrich
You can massage these packs to continue to work if you have a runner. You can parallel a cell into the runner to bring it in line with the others. It probably wont look pretty, but it can be done.If it's 1), keep in mind that these packs are irreparable. If one cell in your pack runs, you get to throw the whole pack out. Unless there's a good reason these are on temporary sale, then I doubt you're actually getting grade A, perfect, new, matched and batched packs for this low of a cost, which means that, as a whole, your investment is unlikely to last as long as rated. Even if a cell does go bad, I replace it and move on. You've got six packs. If one cells goes bad you lose 16% of your storage capacity, and by that time the available packs will be sold and you'll be searching for a replacement that doesn't match the rest of your system.
Here is an example (not my setup) on the old BYD packs: https://diysolarforum.com/threads/byd-packs-—-one-year-on-—-survey.15631/
