jameshowison
- Jul 30, 2021
- 184
In the manual for the 48v 3000W Victron Multiplus it specifies 2AWG wire from the batteries/busbar to the inverter. I'm trying to understand why.
Regular draw is 3000W ie about 62 amps (at 48v, so actually fewer at usual voltages). Peak power is 5500W (ie about 120amps, rounding up).
Using a wire calculator at explorist.life even at 20 feet length (ie 10 feet positive, 10 feet negative), 48v, and 120amps (and 3% voltage drop) I'm seeing 6AWG specified.
The Jakiper 48v server rack battery is saying 120amp max draw (and less than 100 continuous), so that matches well with the inverter. They specify 6AWG (and that's what they use internally within the battery). Even paralleling the batteries, which could increase the draw, the draw is not going to be higher than 120amps (since that's the max the inverter will pull).
So I don't understand why the manual specifies 2AWG rather than something like 6AWG.
Likely I'm missing something, but can anyone help me resolve that? Is it an attempt to minimize voltage drop, resistance, and therefore ripple?
