Mattb4
Solar addict
To kick off the controversy.
Of the various number found on the panels specifications I find the Isc (short circuit current) to have the least practical use. I say it is no sense to even worry about it. It really only happens when you direct connect the positive of a panel (or panels in Series) to the negative. As a test of the diodes perhaps it has some significance but it is not gong to happen under a load situation to a SCC. If you size your circuit protection for Imp than it will react before you can reach Isc.
While using Isc for setting the SCC input capability is often mentioned in real use the Imp is what the SCC is tasked to handle. Amperage limits and time are important to heat dissipation capability of the SCC. I can not see a circumstance where you would have Isc at your SCC for any length of time and especially not if your PV circuit is fused for Imp.
So in my thinking you should plan your PV and SCC requirements using Voc, Vmp and Imp. Isc is simply a curiosity.
