Since voltage is the pressure needed to push past resistance, ALL electrons move with zero resistance… cause as the borg pointed out…Superconductors Vs. Ohm's law
For V=IR, if R goes to zero, then V is always zero. If there's no voltage delta, how can electrons even move?
I'm mad that this makes sense at face value.Superconductors Vs. Ohm's law
Sorry about that... There is still resistance in the circuit and therefore voltage drop - but it's in the device not the superconductor.I'm mad that this makes sense at face value.
Nope. Zero resistance electrons go brrrrrrrrSorry... There is still resistance in the circuit and therefore voltage drop - but it's in the device not the superconductor.
If there wasn't resistance in the device then the current would pass through without doing any work.
Talking about the device, not the conductor. A device must have resistance in order to do work.Nope. Zero resistance electrons go brrrrrrrr
The electrons were put into a state of motion by the initial voltage (what you call the set up). In Newton's first law, an object will not change its motion unless a force acts on it. Normally it's wire resistance applying the opposing motion. But even if there isn't resistance in the conductor, such a ring would still have inductance working against it.... if you set up a current in a superconducting ring and isolate it, the current just keeps on keeping on....
Definitely not on the same page, but don't worry about it.No device.
My mistake, there's so much inaccurate science fiction... thought I'd help eliminate it ... to that endeavor...You do realize you're posting in the humor section right?
Couldn't be infinite current, induction would limit it....Only infinite current.
Kirk wants more power...Dilithium crystals do what they want.
It wanted to be over there.Now if you could just explain Quantum Tunneling.
Hah... the new Dewalt usb cables from home depot go in either way...
It's Bi?Hah... the new Dewalt usb cables from home depot go in either way...
Hah! A physics breakthrough! A fourth state, would that be Suprapositional?Hah... the new Dewalt usb cables from home depot go in either way...
