D90Don
I currently have a 24v Outback MPPT Controller with FLA battery bank, and I am upgrading to a 48v Victron RS450/100 Controller with SOK 48v Battery Bank Rack. Every "how to" video I have seen only has a positive and negative connection from PV array to the Victron Controller. I have not seen any combiner boxes with a neutral that is bonded to the ground in a PV Combiner Box. I have two questions, can Iegally disconnect the neutral in the combiner box, put a wire nut on it, and leave it? Second, on the sub/aux panel that joins the PV array wiring to the Outback Controller, again we have (4) wires, versus just a positive and a negative. The breakers do not appear to be DC in this box? I purchased the property with this system on it, and I am unsure of the logic behind it. Any thoughts or recommendations on how best to proceed with wiring the Victron Controller and safely dealing with this neutral? Thank you.
