559sanchez93705
- Aug 4, 2021
- 69
Just seems that two minutes is way too quick to be in an overheat situation unless the draw was hard for it to cope with
Well my frigid amps r 6.0 @ 115 volts = 690watts if you double it will beJust seems that two minutes is way too quick to be in an overheat situation unless the draw was hard for it to cope with.
1,380watts which my inverter should Handel but if it triples it will be
2,070 watts which will cause my inverter to shutdown that would be the compressor start up.
