I have a 10k btu frigidaire 450 watt high seer low start capacitor window AC that easily runs off my 2000watt generator.
If you have a 4kw inverter running off of a battery to run a 500 watt AC all night long it seems like the inverter would be overpowered and draw unneeded power all night from your battery just to run 500w. Is this correct? If not how much power would be drained off my batteries? 500w x 10 hrs = 5kwh or is it closer to 4000w x 10hrs? If it is 500watt x 10nhrs then the price is not much more from a 2kw to 4kw inverter, so then why do people not always buy the 4kw inverters?
My thought is to make a variable output system and get a couple automatic stackable 2000w inverters then if you run the AC all night but you need to use the microwave or coffee maker in the morning then a second inverter would turn on. We are super tired of turning things on and off for our 3500watt 2500 continuous generator Thus you would only be using half the power all night. Is my logic correct? I wonder if a 800w and one or two of the 2.4kw MPP can all stack together and only run the extra 2.4kw inverters for microwave, washer, coffee pot etc all at once type of scenario.
My energy needs are about 5,000 to 6000 KW for 3 hours when I get home. I may get a third to kick on if my wife wants to run her insta pot or microwave without turning off the RV roof AC or the 120v LG washer/dryer combo. Then when we go to bed we only use about 500w for window AC in our room. We would need about a dozen battle born batteries for two days of power.
Can the MPP PIP do this with the parralell modules but then also have auto generator start if the batteries go too low bc of a cloudy day or something?
I'm also thinking 48v is the way to go. I read the Tesla batteries put out 60v so 48 nominal and when they get cheaper as people upgrade their batteries I'd like to keep adding more old tesla car batteries. Is this logic correct - It's from Handeeman Youtube channel. I seem to now see 24v modules all over ebay so maybe the clear plastic model S is 24v modules not an older 48v style. 48v kicks me up into the 4k inverters though arg so if I can get old tesla 24v modules then 24v seems the way to go.
I think it's smarter to have a variable output system like I'm thinking to save battery power and if the price difference is only $699 more for another inverter vs more 1000s for more batteries to power the 4kw. I can always add more batteries as they get cheaper and stack 3 inverters later to get 6kw if my wife wants it.
Summary ?s
1.) So can multiple MPPs charge a single battery bank when stacked and slaved?
2.) Is there auto Genny battery charge? Or I have to turn on the Genny? Update: yes the LV2424 has Genny start.
3.) Are Tesla batteries 24v now?
4.) Can an 800w MPP run my night AC and be stacked with a 2.4kw MPP. Then I have an even lower consumption but high available when I need it.
Summary ?s
