mytoolman
- Apr 2, 2020
- 36
Hi Guys
I am trying to power the office in my mobile tool store and wonder if the Bluetti AC200MAX is what will work for me.
Here are the ENERGY AUDIT RESULTS: I ran the 120 volt office electronics audit for 16:08 hours/0.61 kWh *** 0.36 WATTS/50 VA *** 0.42 AMPS *** 59.9 Hz/0.74 PF using ***120volts
These results were with the Monitor, Receipt Printer, Laptop, and two cordless battery tool chargers that started out with flat batteries plugged into the Killawatt Meter and my homes wall outlet. I figure my computer, monitor and printer will be powered up 10 hours per day since Im not likely to turn them on and off like I would when I flip off the light switch for the ceiling lights when I leave the truck.
Thinking this through more, To preserve power, I could also just turn off the 120 Volt 6 outlet power strip everything is plugged into and that would power down all my electronics except the laptop which has its own battery.....
NOT included in this test were the TEN ceiling MAXXIMA model M84426 LED light fixtures that are hardwired into the present battery bank. EACH LED 1200 Lumen Light Draw 12.8V = 1.32 amp, A typical day the lights are in use between 3 and 5 hours. I called MAXXIMA and the engineer there told me the Ten LED fixtures use .80 kWh in 5 hours
I like the idea of using a Bluetti stand alone type Portable Solar Generator to replace my current bank of Float batteries if that is possible. Im inclined to go for something like the Bluetti AC200MAX. It looks like folks use this in their living situations where they plug in appliances AND the same office type electronics I use with this unit and it supplies their power for long periods of time.
Is a Bluetti AC200MAX a viable solution for me? Can I get more that one day use from the AC200MAX before I have to lug it out of my truck to charge it on a 120 wall outlet? Im not able to park the entire truck where the shore power is.
What will two 100watt solar panels do for me using the Bluetti?
