I'm installing a 24,000 BTU AC/DC Hybrid Solar Air conditioner and can't get it to work optimally, so I'm wondering if increasing to a 4s2p from a 3s2p will cause any damage.
Here's the data
Solar AC Unit Requirements:
The first setup I tried was a series of 6 panels, but that didn't even get the compressor running without shutting off. I assumed I wasn't providing enough amps to power it up fully.
I then opted for a 3s2p which got it to run at 26 degrees C in peak sun conditions since now I'd be giving it close to 20A and 2520W, which should've been perfect. However, that still didn't work. So my assumption is the unit is only working off 15A, which would give it 1890W instead of 2520W.
Now I'm considering doing a 4S2P as that would give it the actual 2,520W at 15A? However, based on the data, wouldn't I be giving it more than 3KW and damage it if I do that?
Here's the data
- Max. Solar Power Input - 3KW
- Max Input Solar DC Voltage - DC 380V
- MPPT Voltage range - DC 100-360V
- Max. Short circuit Current - DC 15A
- Pmax - 415
- VOC - 50.41
- VMP - 42.18
- ISC - 10.51
- IMP - 9.84
- Pmax - 314
- VOC - 47.16
- Vmp - 39.41
- ISC - 8.41
- Imp - 7.97
