I tried taking my batteries down to 5% the other day, and it looked like they were falling off a cliff. While I did not get any battery disconnects, I have decided to leave the ChargeVerter cut in at 10%, and I set a non-silenceable alarm on my phone at 5%, which should (?) give me a half an hour to check for issues and/or fire up the generators.
Remember the normal LFP Voltage Curve.
Steep Fast Drop after you cross the 2.800-2.900 Volts per cell. The Infamous Cliff Fall.
Then the other side from 3.500 +/- to 3.650 is "Runner territory" where weaker cells to run to HVD.
AH between 2.500 to 2.900 and from 3.500 to 3.650 typically only represents about 2-4% of "Gross Capacity" (not net capacity which is the Working Voltage Range)
Depending on Cell Grade, Bulk, B or A etc the base Voltage where the cells drop or climb fast will vary.
I run a mix of EVE 280's from V1 to V3 and everything in between, including 2 franken-packs with V1 & V2 cells mixed together.
A Current JKBMS Inverter Model 2A Active Balancer (V15 HW).
The MOST they ever get out of balance is just at the point where Absorb transitions to Float. It is NEVER more than 0.020mv apart.
Within 15 minutes of FLOAT, All Cells in All Packs are within 0.005mv.
All the packs in the bank will remain that way till just a hair below 3.000 Volts per cell where they start to deviate a bit more again... By 2.800vpc, the max deviation may be 0.030 +/- 0.005 at which point they shutdown. Only gotten there during Thrash Tests, the bank never gets below 2.900vpc.
The Charge profiles, BMS settings I use at home and on systems I have installed out in the wild ALL perform pretty much identically and without issues. Some of those are heavy Loaders as well (1 Greenhouse & 1 saw mill).
I have active balancing start @ 3.42V. Bulk/Absorb run at 3.475vpc while Float runs at 3.435vpc. HVD is set to 3.510 and HVDRelease at 3.455 so the cycles stay tight & fast BUT due to my charge profile HVD never gets triggered.
Lastly, all of the above stays consistent regardless is the packs are at 15C/59F or 40C/104F temps. * Charging slows up a bit over 35C/95F.
A "Catch of sorts". All my packs are DIY. I have Bulk, B, A Grade cells (pending on pack & vintage). They have ALL been TOP-Charged to 3.650vpc @ Cell Level and allowed to charge until 1% of stated AH (2.8A for a 280AH cell), then "Set Balanced" all cells charged to same Voltage and allowed to balance between themselves before assembly. WEnsuring the Chemistry is fully activated and all available capacity is actually available.
This is My Setup & Settings which I have come up with over the years and it all works flawlessly without any concerns or regard. Each pack is assembled & built the same. All Heavy Cables etc are all exactly matched & to identical specs (length/gauge/nickel plated lugs etc). Granted I only have 1,960 AH in my Home Bank but it does exactly what it must and how it must.
Hopefully this is of use to some and good luck.
Just remember ONE THING, everything is Your Choice, Your Decision and ultimately Your responsibility for good or bad.
Most importantly, it is Your Wallet not the person who is giving you advice ! Your dog is the one running in the race, not theirs.
