flowerspower
I am retrofitting my RV with a solar power system to be able to run my newly-installed mini-split AC. I ordered and have since received 16X EVE 3.2V 280Ah Lifepo4 batteries. Originally, my original plan was to create 4X 12V batteries by connecting 4 of the EVE cells in series, making 4X 280Ah 12V batteries. The system will provide 1120Ah of power. However, this configuration would require 4X BMS units (DALY Smart BMS 4S 12V 200A), which I think may be overkill with regard to requiring 4 BMS units. I now am thinking of making 2X 12V banks by connecting pairs of EVE cells in parallel then connecting them in series (8 cells per bank) then connecting these 2 units of 8 in parallel. This would lower the requirement of BMS units needed to 2. One question is regarding connection of the BMS balance wires (4 total) for each bank. I would connect each one to a pair of cells connected in parallel. Would this be an ok configuration or should I just spend the extra $$ and use 4 BMS?
